Autosave Popup
ELSID
8-Gravel
Autosave Popup
Developed a weird pop-up which is due to Auto Save. Never had it before. Suggestions?
TomGutman
(To:ELSID)
Try a shorter path name. Mathcad's autosave tries to encode the entire absolute path name into a simple name, which then becomes a part of the path name for the autosave file. As you can imagine, with this structure it is easy to get path names that are too long.
__________________
� � � � Tom Gutman
Will try in the am. As previously mentioned, this is a new anomaly. Been working/tweaking this file for a month and never had this happen before.
