Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Try a shorter path name. Mathcad's autosave tries to encode the entire absolute path name into a simple name, which then becomes a part of the path name for the autosave file. As you can imagine, with this structure it is easy to get path names that are too long. __________________ � � � � Tom Gutman
