Better Fit
awibroe
Better Fit
Hi to all,
In the attached (MCP3) file, can anyone give me some suggestions on how to get a better plot of f(x)? I have tried varying splines but the plot is quite erratic toward the end where as I would expect it to be quite uniform.
Andy
(To:awibroe)
I guess a polynomial of 9th degree is too wavy, too?
Its interesting that we can even demand for a higher order polynomial:
DJF
(To:awibroe)
Here's a Schumaker quadratic spline.  Bit of a kink at 80, but it's closer than what you had.
I fit the quadratic and then fit that with a b-spline so you can use it easily.
4.0 and pdf attached.
Also, linear interpolation might be good enough for your data, but there's not much fun in that.
(To:awibroe)
LucMeekes
(To:awibroe)
Is this the measured filter characteristic  (X in Hz, Y in dB) of an elliptic low-pass filter? https://en.wikipedia.org/wiki/Elliptic_filter
Or a Tshebyshev low-pass filter? https://en.wikipedia.org/wiki/Chebyshev_filter
Then you should be able to find a better fitting with the corresponding filter formulae.
It would also seem then, that you did not measure enough points to accurately catch the passband ripple: considering the very steep roll-off after about 80 Hz I'd expect many more ripples in the passband.
Like this:
awibroe
(To:LucMeekes)
Hi, no this is points on a stability curve that I’ve created in MC for a ship. I extracted the points to a fresh sheet to make this easier. Yes I guess I could have simulated more points...
Cheers
Andy
