Bug in Mathcad 15 M030 (symbolics)
I would call this behavior a bug. The integral is only found if the symbolics is forced to float mode (it also happens if you use the "float" keyword).
Does anybody know when it was introduced or can anybody confirm the bug in earlier versions of Mathcad than M15 M030?
AlanStevens
(To:Werner_E)
‌It works in M13 and earlier, but not in M14.
Alan
7 REPLIES 7
RichardJ
(To:Werner_E)
I do believe that in the past you have requested users to post their worksheets, because we (in this case "we" includes both you and I) don't like to (a.k.a. are too lazy to) retype stuff
(To:RichardJ)
Hmm, wasn't that the case with much longer sheets and expressions? Its so much easier to insert pictures just by cut and paste (the only improvement in the new forum).
Anyway, here's the sheet 😉
I hardly can image that I would not have come across that bug in the past, so I suspect it to be a rather newly introduced "feature". But then, I may be wrong.
AlanStevens
(To:Werner_E)
Alan
(To:AlanStevens)
Alan
Thanks! So its really an older bug which was present from the very beginning (of muPad).
The bug is also present in Prime, of course
Werner
RichardJ
(To:Werner_E)
Maybe. Or maybe I'm just lazier than you
It's obviously a bug. I was going to try it in MC13 and MC11, but I see Alan got there before me. I thought it would probably work with the Maple engine, but it wasn't impossible the problem was with how Mathcad parsed it.
The Mupad engines handling of definite integrals is so poor it's comical, and this is just another example. You are often better off solving the indefinite integral and substituting the limits by hand:
StuartBruff
23-Emerald V
(To:RichardJ)
It must surely be long past the time when PTC get rid of MuPad (and its associate licencing restrictions on what functions/operators can be used and how).   There are enough symbolic engines floating around out there now that it's likely one would be a potential (and available) candidate ... they could even consider adding Python as a scripting engine for the Prime "components", and get licencing for SymPi.
Stuart
VladimirN
(To:Werner_E)
I have the same result in Mathcad 15 M040 service release.
