8-Gravel
October 8, 2015
Excel file in Mathcad 14
  • October 8, 2015
  • 2 replies
  • 7041 views
Hi all!
I'm trying to embed an excel file in mathcad 14 using the    insert--> component--> excel file--> "create from file" (display as icon).
All I want is data from A1:A166053  (i know it is a lot of data ), this data represent the significant wave height since 1957.
After I "create from file" I select 0 input and 1 output and then define the range i need. When this is done the icon appers in mathcad and I define the
name. In this case "Hs". Then the error message "The range value specified is invalid" appears...What am i missing??
Regards
Sigurd Næss
What version of Office/Excel?
Note that Mathcad 14 is around for some time, and MS have changed Office significantly since then. Mathcad 14 may not know how to handle.
To be independent: Copy your one-column data to a Notepad file, save as .PRN file and use READPRN to read the data.
Then you can process.
The other way 'round is to make sure your excel data is saved as office 2003 or earlier...
snã¦ss8-GravelAuthor
8-Gravel
October 8, 2015
Thank you for the answer i will try this tomorrow.  I have office 2010,
Regards
Sigurd
8-Gravel
October 10, 2015
Hello again!
First! Thank you all for contributing to my question, things got a bit too advanced for me towards the end, but all is appreciated
I managed to import the data, I included a new column which represents the year the wave height was collected. Is there a way to find out the max value for each year, and have that returned in a nice table?
I tired a bit myself, extracting submatrix for a year and finding the max value for that submatrix. But I couldn't make Mathcad do all the steps from 1957-2014.
Hope I expressed myself correct and I appreciate all the help I can get
Regards
Sigurd
23-Emerald V
October 10, 2015
Sigurd Næss wrote:
Hello again!
Regards
Sigurd
Hi Sigurd,
Is this of any help?  There's another approach in the worksheet that uses a few of my utility functions to extract the data.
Could you please post the data file as well?  It will help verify the solution.  Thanks,
Stuart
8-Gravel
October 11, 2015
Wow! That looks great!
Sigurd
