Bug in Symbolics or ignorance on my part?
  • February 1, 2012
  • 5 replies
  • 10436 views
Can anybody explain, why the variable x is not known by the symbolics machine? Is this a bug or am I doing something wrong?
In my original file x would be a much larger list of more or less arbitrary numbers which can not be derived by a function. I mention this, because defining x.i:=3*i would not produce that error.
Regards
WR
An other variant:
I think we cannot use this operator in symbolic calculation:
It doesn't like the way you have defined the vector "a". I'm not sure if the way you are doing that is officially supported or not (I have seen it before, but I can't find it anywhere in the documentation). If it is, then it's a bug. If not, then arguably it isn't. If you define your vector using insert matrix or insert data table, it works.
The construct is a comma-separated vector.
Mona
OK, it is documented
So the fact that the symbolics will not recognize it is a bug.
I think it is a bug. Frequently I get that message (Undefined variable) and I solve the problem only by deleting the variable and typing it again in the affected equation.
I tihnk that is something different. Next time it happens please post the worksheet here.
I don't think the symbolic algorithm should be able to do a summation on a range variable. Range variables are for indexes. Valery has shown how everything works if you create a real vector. The "comma separated vector" appears to be still a range variable, not a vector. I wouldn't regard this as a bug.
