Can I get more than one output from a program
h_nas
I am trying to get three output from the same preogram. is that posible?
30 REPLIES 30
Hinnd Naser wrote:
I am trying to get three output from the same program. is that posible?
Yes, just a matter of programinging for that end.
RichardJ
(To:jeanGiraud)
While that answer is undeniably correct, I don't think it's all that useful!
Quite correct in this "Théâtre des variétés" !
RichardJ
(To:h_nas)
Yes, but only if the outputs all have the same units. Make the last line of the program a vector with the desired outputs.
h_nas
(To:RichardJ)
can use more than one input, and get an output for each one.
Thank you
RichardJ
(To:h_nas)
Sure. If Pointless is a function definition just pass the function more than one argument. Or if Pointless is just a variable assignment rather than a function definition, it will pick up on any variables defined prior to the program in the worksheet.
h_nas
(To:RichardJ)
The examples you provided at the time where very helpful. However at the moment I am looking at an input coming from a matrix, say x value will be from 1 to 100, if I run for example the pointless program in the end I will get the answer for the last run, but I need instead the output for all x values from 1 to 100?
Thanks in advance for any help.
MikeArmstrong
(To:h_nas)
Please provide a worksheet of you data. Simple example shown below.
Mike
h_nas
(To:MikeArmstrong)
See attached a simple example of what I would like to do, and what I get from mathcad, I am unable to change the units of the output either.
MikeArmstrong
(To:h_nas)
I haven't got Prime at the moment, but you can convert the file below.
Firstly check that the output of the program is in Matrix instead of Table.
Obviously I can't have mixed unit arrays in M15, so I have omited the units.
Mike
h_nas
(To:MikeArmstrong)
Does that mean I am unable to use mix of units with programs whaich have many inputs??? as at the moment my current program doesnt work ( I am getting the last run), and I have no control what so ever on the output units!!!
MikeArmstrong
(To:h_nas)
No, Mathcad Prime allows mixed unit arrays. Have you converted my worksheet to Prime?
Mike
h_nas
(To:MikeArmstrong)
Sorry the MP1 was crashing, however I got a result but I cannt change the output unit to bar & m^3/hr.untitled.PNG
and one of my equations is V, and MP1 consider it as a unit V, not as a parameter!!!!
MikeArmstrong
(To:h_nas)
I'm not 100% certain, but I'm sure Mathcad Prime defaults to the standard dimension system when dealing with Mixed units arrays. It seems to be defaulting to SI.
Mike
Fred_Kohlhepp
23-Emerald I
(To:h_nas)
It's not clear what you want. Are you solving for the product of the two terms? Or just returning M and N?
Try adding one line to you program:
h_nas
(To:Fred_Kohlhepp)
No, I am not solving the product of two terms, I am returnig M and N.
Fred_Kohlhepp
23-Emerald I
(To:h_nas)
So why do you need to program it?
I agree with Fred, unless your trying to learn the principles of programming, I would use a range as Fred has.
Mike
h_nas
(To:MikeArmstrong)
Thank you, for your help.
I went with your example for example sake, My original program has many inputs, I need to run the calcs four times min (each run has six complex equations) , for differnt set of input. at the moment I am using MP1 table for inputs i.e. I am using the loop so the inputs will be read from the table depending on the the counter value i.
The errors I am getting is:
  1. I am getting the result for the last run.
  2. One of my equations is V, but when I type V in the result or return step, MP1 considering V as a unit (volt).
  3. I am unable to change the units of the output, for example (kPa to bar) and (°C to °F).
Thanks for your help anyway, I will see what PTC have to say about these issues.
Hinnd
MikeArmstrong
(To:h_nas)
  1. That will be the way you have set the program up. You have posted an example above where a range of results has been calculated.
  2. It is good practice to keep away from built in variables.
  3. As I stated before, I believe this is a limitation of Mathcad Prime 1.0.
Good luck.
Mike
h_nas
(To:MikeArmstrong)
I found a perfect example in mathcad 15 help tap, it is just what I am looking for (which is a miracl), however, when I re write the same program I don't get the same result. I will attach it soon.
MikeArmstrong
(To:h_nas)
Can you please upload your latest worksheet?
Mike
h_nas
(To:MikeArmstrong)
Below example from Mathcad 15, please note that I cant get the same answer.
h_nas
(To:MikeArmstrong)
and Mathcad program as attached.
MikeArmstrong
(To:h_nas)
Like the attached? You hadn't incluided the Matrix transpose operator.
Mike
h_nas
(To:MikeArmstrong)
Go a head and have a try, and show me!!
MikeArmstrong
(To:h_nas)
Worksheet attached.
Mike
h_nas
(To:MikeArmstrong)
See what I get when I do the same!!
Hinnd
MikeArmstrong
(To:h_nas)
Double left click and select Display Options and check the Expand nested arrays box.
Mike
