example f(x)=ax ,
I want to plot for any variable of a
You need to make the function depend on 'a' as well as 'x'. The attached shows how to do it using a slider to vary the value of 'a' (though you can set 'a' any way you want).
Alan
Or so
Thanks , very much . this was helpful
but , Is there another way (other than the slider method) I can plot the function without specifying any values of a
OR just specifying an interval like a=[0, infinity]
You can't really expect Mathcad to plot without knowing one or more values of 'a'!
However, you could plot a surface using a 3d plot for a specified range of values of 'a' and 'x'.
For example:
Alan
A solution of the z(x, x) without an an an an an imation is not solution:
