Hi, I am wishing to solve a Hertzian contact problem for sub-surface stresses for multiple points in order to plot contours. The solution routine uses Polyroots to extract the maximum root for use in the calculation and works fine for a single point. Is it possible to automate the process in a loop for variable x, y and z using Polyroots? I tried a couple of attempts but get errors.
Any assistance would be appreciated.
Thanks Ross
FM,
Thank you so much for your assistance in working on my problem. You have been very generous with your time and have earned a holiday!
Best Wishes
Ross
I regret to tell you, but if you are satisfied with the answers, and do not wait others, you should conclude marking an exact answer.
Thank you
With best regards
FM
