Can't install MP1.0b
GuyB
I can't get the program to install to my primary computer, though it did install on a different machine.
The error message I get is:
"The system cannot open the device or file specified."
When that dialog box goes away I get another one which states, among other things, that "The error code is 2755."
I'm running WinXP Pro SP3 on a Dell Inspiron 9400, T2400 1.83 GHz. I have the latest .NET stuff. My anti-virus program is Symantec AntiVirus ver. 10.1.6.6010, scan engine 81.3.0.13.
- Guy
8 REPLIES 8
IRstuff
(To:GuyB)
>machine.
>81.3.0.13.
> - Guy
XP Pro SP3 on Dell Latitude D531 TK-55, Symantec 10.1.5.5000 81.3.0.13 runs, but crashes often.
Windows 7 RC (32b) on HP Pavillion Q8200, running NAV, crashes occasionally as well.
TTFN,
Eden
Ninetrees
(To:GuyB)
So far, I am running OK. Windows XP Pro SP3, updated .NET, Dell Inspiron 9400, ZoneAlarm Pro.
The thing I did notice a change in the Help system, but will note that under a different thread.
Rich
http://www.downeastengineering.com/
mzeftel
(To:Ninetrees)
Guy, Eden, and Rich,
Are you still having problems installing and running the software? If so, please send an email to the -.
Mona
GuyB
(To:mzeftel)
I think I figured it out, though it's weird.
I automatically encrypt the data files on my hard drive, using WinXP Pro's file encryption property.
When I placed the file in a different directory and removed the encryption, the program installed.
- Guy
IRstuff
(To:mzeftel)
>an email to the
>Mona
No, everything's running, Seems to be more stable on XP than W7RC.
TTFN,
Eden
Ninetrees
(To:mzeftel)
The only problem that I had with respect to installation is one that I mentioned right away with the Help error (48, not sure?). And Help actually looks different now from the way it looked right after installation, so I am thinking that there was a need to reboot right after installation. Right after installation the other day, Help looked a bit strange; now it looks much as I expect it to.
Rich
>reboot right after
>to.
>Rich
>.com/
I also had a 'problem' with help and tutorials as well.
I noted that a cmd window came up during install. On pc restart there was an MS update waiting install... not sure if a factor.
Also the tab with the help and tutorials don't work either, but the (?) button does (onec I found it / re-read the instructions 😉
Problems have been reported.
Philip Oakley
StuartBruff
(To:mzeftel)
== Are you still having problems installing and running the software? If so, please send an email to the -.
I had a problem installing in 'normal' Mathcad folder (C:\Apps\Mathcad\...) but it went in happily in the 'default' C:\Program Files\Mathcad\...)
Stuart
