This widget could not be displayed.
Catenary
ValeryOchkov
Catenary
I need fresh ideas for the task (Catenary) in attach!
Thanks!
Val
http://twt.mpei.ac.ru/ochkov/v_ochkov.htm
6 REPLIES 6
You can add the calculus for the stress at the minimun curve value and some safety factor to the horizontal tensions. Further, add a real manufacturer table with usual values for cables and show how to select the appropiate, at least, for the mechanical properties of the cable.
Can relate also the safety factor with some increments on the weight, as the ice.
Also can write the problem as the differential equation of the equilibrium of the tensions for a small cable element, but it is assumed that you want a geometry view point (and post here, in "Algebra & Geometry")
I don't remember if is in the Elgostz's variational calculus book (which have not at hand) or in some other russian author that there are a very nice example that minimizing a functional the result is the catenary, but can't remember which functional it is or how to recostruct the example, but even use differential calculus it is a very 'geometric' example.
For geometrics also, can add some wind and see the curve into the 3d space, or as a vibrational question, checking that resonance frequencies are not closed to the natural freq of the cable.
Regards. Alvaro.
Valery can do all that, the readers can try too.
1. Professor of mathematics.
2. Doctor in "Technology of Information".
3. #1 in DE's.
4. IAPWS ... etc.
5. collab "Emeritus"
jmG
Thanks, Alvaro and jmG.
Now I am preparing one gift for my mathematical friend - one wall-picture with two Catenary - a real and a virtual covered the real.
The virtual Catenary is here ( http://twt.mpei.ac.ru/MCS/Worksheets/chain-frame.xmcd )
The gift by the testing is
Val
On 1/28/2010 4:10:29 AM, adiaz wrote:
>Very nice idea! Actually,
>catenary came from
>catenarĭus, proper of
>chain, in latin.
>Regards. Alvaro.
_________________________
There are two kinds of catenary:
They are both solution of their DE:
1. Ignoring the section of = resistance cosh(,)
2. as function of = resistance cos(,)
Suspended bridge is parabola, not "chainette".
jmG
Now I
>the real.
Very clever!
Well done,
- Guy
