Cell counting
ptc-5743339
Cell counting
Hi!
I'm trying to develop a program wich can count the number of cells contained in the following image:
For such a task, I need to find the perfect values for the canny function in order to performing a succesfull "reg_grow" wich "paints" each of the cells as a white circle and then the task of counting those white circle is easy.
So, here is my attemp: Some of the cells are succesfully colored, but other ones still being without coloring.
I really hope that this would be a matter of the values in the canny and reg_grow functions rather than a problem with the image itself.
Thank you.
(To:ptc-5743339)
I hought the goal was people counting?
Did you look at the last post here; http://communities.ptc.com/message/237229#237229 ?
Yes, I've seen that post and was extremelly helpfull.
That program was that helpfull that my company wants me to use it in a lot of different examples, different from people counting, such as this...
(To:ptc-5743339)
I can't think of any automatic procedure giving you what you want for any pic. But then I'm not that well versed with image processing.
