Circle line intersect
ptc-1368288
Lea,
Here is the 71 pages work sheet between your first visit in this collab and your e-mail. Pages 14, 15, 44, 59 are for the circle centered in the Cartesian [0, 0]. The "goat" problem is another case as it leads to Valery constant. The level control is another case with the line horizontal. For these two cases, the intersection were not analyzed.
Hope it helps. I will read your work sheet again.
My e-mail does not send, maybe a parental control is still active ? For the big sheet, follow the instruction at the top of the page, strictly !!!. Some 3D might lose specifications ( a bug in Mathcad 11.2a).
Apparently, 14 does not like the serial definition
if so: convert it
Jean
RichardJ
(To:ptc-1368288)
It handles that example just fine. In version 11 the elements are assigned sequentially (which is arguably a bug). In version 14 all elements are assigned simultaneously. So if the first and second elements are a:1 and b:2 it will work in both versions. But if the elements are a:1 and b:a*2 it will not work in 14 because in the second element "a" is undefined.
Richard
>"a" is undefined.
>Richard
__________________________________
Thanks Richard,
Finally, that work sheet is just fine in 14 ?
If so, quite happy.
Jean
RichardJ
(To:ptc-1368288)
>14 ?
More than 95%. There were a couple of places it turned red, but I didn't spend the time to figure out why.
Richard
