Combined Radiation and Convection
ptc-5133430
Description:
Radiation heat transfer rarely occurs by itself in a building. It is usually coupled with convection. Several such cases are considered in this section.
First, we determine the total U value of a double-glazed window, and the radiative and convective heat transfer coefficients in a cavity. Then, we consider a thermometer, which is used to measure air temperature, and determine the error caused in the measurement due to the radiation effect. Finally, combined radiative-convective heat loss from an exposed pipe is calculated.
0 REPLIES 0
