We’re aware of an issue preventing community login. Our team is actively working on a fix and we’ll share updates as soon as possible.
Combining/Interpolating Mismatched Data
MoeSzyslak
Hi, All --
I have some data that I digitized from another source. Essentially, I digitized a plot of p vs. q and another of p vs. e. However, what I really need is a plot of q vs. e. The problem, of course, is that since the data are digitized, the two data sets have a different number of rows and also different values for p. To make matters worse, the p-q data increase and decrease in both variables, so they can't be splined. I guess I can think of a couple of brute force ways to attack this, but does anyone have a slick solution?
Thanks in advance.
Matt
20 REPLIES 20
Could you not just add a secondary axis?
Mike
Hi, Mike --
Thanks for looking at my problem. However, I'm still not exactly sure what the second axis gets me -- I understand your point, but I still don't have a plot of q vs. e that is easy to understand. Am I missing something?
Matt
Maybe I missed something. You have called your variables p_e and p_q, I take it these are actually four seperate variables?
Mike
No, you got it right -- p_q has p in the first column and q in the second -- p_e is the same. The two data sets are (theoretically, but I cannot confirm) from the same test, but digitized from two different plots.
Matt
Sorry my mistake. Can you not change the range on the digitize to modify the number of rows?
Are you performing the digitize through Mathcad?
Mike
Actually, someone else digitized the data. I don't know how they did it. That said, I typically use DataThief for digitization. It can follow a trace of a given color and provide as many data points as are necessary to define the curve (for the original p_e curve above, it was about 950 points). Thus, it is not trivial to get the exact same number of points on each curve.
Matt
Yes it it trivial. If you can obtain a copy of the graphs, there is a digitize which Valery has passed within this forum which might help.
Mike
Ahhh...that's news to me. Do you happen to have a link? Or, do you know the topic of the original thread?
Have a look at the attached.
Sorry I couldn't look into your problem in more depth, mad busy at the moment.
Mike
Mike --
That looks great. How do you assign the picture to a variable? I've been playing with the matrix toolbar, but can't get it to work. Do I need to copy the image from another application and paste it?
Also, looking at the function, I still don't see how I can guarantee the same number of points in the traces, even if the images are the same size (i.e., the lengths of the lines could be different).
Thanks again.
Matt
EDIT: I figured out how to insert the image.
Thanks for that worksheet.
Have a look at the attached, I have used a brutal method, using predict function to get a result.
Mike
Mike --
I don't think this works, exactly, although I am not familiar with the 'predict' function. It looks to me that you need to apply 'predict' to q rather than e since rows(q) < rows(e). When I try this, I get poor (i.e., negative, which is physically impossible) values for q. I'm not exactly sure what 'predict' is doing to e, because it appears to be trimming much of the original data from the top of the vector -- i.e., min(e_orig) = 0, min(e_modified) = 5e-3.
Thanks again.
Matt
Yes I agree. I'm sure Richard might have an idea how to solve this issue.
Mike
Can you say whaat this is data of? Looks like (maybe) a test of something to failure; both e and q have two different values for the same value of p. This suggests that something changed as the data was acquired. Is the data sequential in time order? (If we plotted the data in the order it's listed are the values in the order acquired?
Fred -- yes, the data are sequential in time. The variables p, q, and e are mean stress, deviatoric stress, and axial strain, respectively. Thus, mean and deviatoric stress were increased at some constant rate and then mean stress was decreased while deviatoric stress was held constant.
Note that even though both data sets are sequential in time, I have no reason to believe that delta-t is the same for both because we aren't plotting the actual measured data. Does this make sense?
Thanks for looking at this.
Matt
It's not pretty!
Fixed one stupid mistake.
Message was edited by: Fred Kohlhepp
Added a comparison to the original data at the bottom.
The comparison shows indications thatthe original digitization may be suspect. Any chance of getting images of the originals?
Hi, Fred --
Thanks for all of your work on this -- it is extremely helpful. I was hoping that there might be an approach that required little or no human interaction, but I am beginning to suspect that isn't the case. I have attached the original images below. I confirmed the p-e data (Fig2) using DataThief and got essentially the same values as those that were given to me (and that I provided on the original worksheet). I hae not independently confirmed the p-q data.
Matt
I digitized (very coarsely) your images to even out the distributions. Things didn't change much.
Then I figured out how to simplify this.
