Conjugate Beam Method to calculate deflection for a symmetrical 3 span beam
JeromeHatlewick
I am currently writing a Mathcad Prime 5.0 design sheet for a symmetrical three span beam.  I have calculated the moments and shear along the beam and have also determined the cracked section properties.  I am interested in how to include the conjugate beam method to calculate the deflection at 10th points along the beam.  Has anyone written a sheet that includes the conjugate beam method as I have stated that I can use as a go-by?
Deflections of a single simply supported span by conjugate beam.
Cheers
Terry
The equations of moment with respect to x distance from left hand side are:
You need to include two more for the end moments -M.lhs and -m.rhs
Cheers
Terry
Thanks, Terry.  I'll take a look at it and see if I can make it work for my 3 span reinforced concrete beam.
I'm also using Mathcad Prime 5.0 so there will be some programming modifications.
The snippets of Mathcad statements work if EI of the beam is constant.  You just need to divide EI to get the value of deflection.
Cheers
Terry
Thanks for the additional information.  I have not yet tried to work this into my Mathcad Prime 5.0 sheet.  I had to make a few corrections earlier in the sheet and haven't had time to try this out.
