Connecting to different instances of Mathcad prime 4
pklemm-2
6-Contributor
I am using Mathcad Prime SDK 3.1 for Mathcad Prime 4 to automate some time consuming calculations and worksheet management. As described in SDK, the communication is done over an
ApplicationCreatorClass() call. This works more ore less fine but I cannot control to which running Mathcad instance the link will be performed. My question is: Is there any way to establish connections to different  Mathcad instances running on the same computer?
6 REPLIES 6
LucMeekes
(To:pklemm-2)
Is there any way you can get the process ID number (PID) of the application instance that you are connecting/ connected to?
pklemm-2
6-Contributor
(To:LucMeekes)
Yes. I can get PIDs of all running instances with
System.Diagnostics.Process.GetProcesses().
I tried another way with OLE32.dll:
Reading out the ROT (running object table) with the IMoniker interface, as it is described for EXCEL connection. After getting a running COM object instance the .Net interface or class must be known like here:
if (lComObject is Microsoft.Office.Interop.Excel.Workbook)
Microsoft.Office.Interop.Excel.Workbook lExcelWorkbook = (Microsoft.Office.Interop.Excel.Workbook)lComObject;
I tried to substitude "Microsoft.Office.Interop.Excel.Workbook" with the automation interface class of Mathcad and also with its Application class but there was no match.
pklemm-2
6-Contributor
(To:LucMeekes)
Hello LucMeekes,
excuse me that I ask you directly, but there is nobody here who has experiences in that except You.
I am always looking for the solution of connecting to different instances of mathcad.
Do you have any more suggestions for me?
did you already ask PTC Support ? If not, please give them a chance...
Martin Hanák
pklemm-2
6-Contributor
(To:MartinHanak)
Thank you,
I didnt but I will do now a request.
VladimirN
(To:pklemm-2)
You can use the "Case Logger" tool on PTC's eSupport portal to open technical support case: https://support.ptc.com/apps/case_logger_viewer/auth/ssl/log
