I need to create a contour plot based on 3 dimensional free data but I'm having issues. I've created a matrix with my data:
and try to do a contour plot but it does not graph it properly. I think the data must be defined on a grid of some sort but I'm not sure how to use CreateMesh since this is free data and not a function. FYI the data is the matrix is (frequency, tuning sensitivity, phase noise.)
I've also tried doing it as a 3-D plot and the data points show up correctly but I need it displayed in a contour format.
I'd appreciate any help.
Matt
On the assumption that columns 0, 1 & 2 in your matrix represent the x, y & z data, respectively, then try typing the following into the placeholder in the contour plot:
(Mat<0>,Mat<1>,Mat<2>)
Stuart
You are correct, columns 0, 1, and 2 represent the x, y, and z data. Here is what my contour plot currently looks like:
which is obviouly not correct. If I try to put anything into the units placeholder it tells me "this variable is undefined" When you say (Mat<0>, Mat<1>,Mat<2>) is Mat short for Matrix?
What I get (in Mathcad 11, I don't have Prime 2.0) is
I meant the plot component placeholder (the black square (or whatever Prime has) where you type the data to be plotted.
Yes, sorry about that, I have a function in my library call Matrix so I shortened your variable name by reflex! ![]()
That is exactly what I'm looking for but I'm not able to get it to work in Prime. I wish I had access to an older version of Mathcad. When I try entering what you show I get "unknown error: bad%_application"
If you've got Prime 2.0, you should either have, or be able to download, Mathcad 15
matt eckdahl wrote:
That is exactly what I'm looking for but I'm not able to get it to work in Prime. ... When I try entering what you show I get "unknown error: bad%_application"
There's an alternative format that works in M11 and M15, it might be worth trying - M is a 3x1 vector. The plot below shows a contour, surface and scatter plot of the same data.
What does Prime Help say about the input format for a contour plot?
I will look into the possibility of getting/using Mathcad 15 (which I would prefer to Prime) but in the meantime Prime help says (regarding input data):
So I think the issue I'm running in to is "the data matrix cannot contain free (x,y,z) data"
I tried to do the vector and for some reason it doesn't like that either. When I tried to plot Mat<0>,Mat<1>,Mat<2> earlier, as soon as I hit the comma it forces me to enter in the X,Y...Z format because it thinks I'm trying to enter a variable range. Man I'm not a fan of Prime so far.
That's a possibility, Matt, and would represent a significant change from previous versions of Mathcad. Unfortunately, I know absolutely nothing about Prime 2.0's plotting. Hopefully, Mona or one of the other readers can provide further insight. I can check later if it's possible to create the nested array M in Prime 1.0.
Stuart
Thanks for your help Stuart, I appreciate it.
Matt
Matt,
If you have Prime don't you also have M15?
Mike
Matt,
You are correct, that Mathcad Prime 2.0 cannot plot free (x,y,z) data in a contour plot. We have been discussing how to add that capability to Mathcad Prime for a future release , so I'll use your data as an example for the developer.
You can add additional traces to any plot in Mathcad Prime. Just press Shift-Enter instead of typing a comma. Or click on Add Trace button in the Plots tab.
Mona
An example worksheet in M11 format, Mona, should it be of any use in supporting the case. Works in M11 and M15.
Stuart
matt eckdahl wrote:
...I wish I had access to an older version of Mathcad...
You can download Mathcad 15.0 free 30-day trial version here: http://www.ptc.com/products/mathcad/mathcad-15-0/free-trial.htm
If he has Prime, shouldn't he also have M15?
Mike
Yes, that's correct. But just in case I gave an additional link.
