Convert nested array to string?
Bartz87
Is there any way how to convert the "z" above to "y"?
Like below?
Mike
thanks mike but it's not what in my mind....what im trying in my mind is something like below:
inside z is a formula which i wanted to convert to a string, is that possible?
I think your going to struggle to achieve that. I have never seen that done before. Why do you want the forumla's converted to strings anyway?
Mike
I see...well that is just for presentation purposes. I want to place the formulas in the excel component in 1st column, and in the next columns will be its corresponding results. So that I will not type again the formula inside excel, especially when there are many of them.
By the way... thanks
If your defining the equations in Mathcad and embedding the Excel component, I don't see why would would need to show the formula again.
Mike
