Convert xmcd files to mcdx
ptc-4127093
Good morning,
I would like to convert xmcd files to mcdx format.
I have Mathcad 15 software and a trial version of Mathcad Prime.
The conversion is refused, probably because Mathcad Prime is a trial version.
Could anyone convert them for me? I have about 15 files.
Thanks in advance
Richard
Zip up the files and upload the archive here.
You never know your luck.
Cheers
Terry
6 REPLIES 6
Cheers
Terry
ptc-4127093
(To:terryhendicott)
A very big thank you. It's very nice of you !
Richard
Here youi are:
Bob
I have converted an XMCD file, which it says was successful, and it has been saved with an mcdx suffix.  Prime 10 will not open it.  Says it is not an mcdx file. All suggestions welcome.
Thanks.
(To:klax)
Strange. Can you post the mcdx file and also possibly the orginal mcd or xmcd file ?
klax
9-Granite
(To:Werner_E)
Thank you for the response Werner. In the meantime I have reinstalled the converter, deleted the corrupt conversion and re-run the conversion,
This time I was able to open it and manually correct some errors in the conversion.
Kind of you to respond.
Kind regards,
