Convert xmcd in mcd and open the file...
ptc-4346041
Hello everything,
Can you convert my file *. Xmcd in *. Mcd so I can open it under premium Mathcad 2.0.
So if a person among you to a powerful computer with more than 4 cores it may try to open my fihchier and send me a copy of the results in word document.
I thank all the forum.
RichardJ
(To:ptc-4346041)
Here you go. I've attached the conversion log too.
9 REPLIES 9
Remplace the variable Ffinf and ffinf2 by 70000 and not 10.
Thank you
If you have Prime, you already have the capability to convert Mathcad 14/15 files to Prime format.
The instructions are here:
http://blogs.ptc.com/2012/04/09/converting-your-worksheets-to-mathcad-prime-2-0-in-3-easy-steps/
no I can not, the button is grayed.
If you want I can do well it would help me thank you
What are you trying to do?
Mike
The button should not be greyed out.
You may need to re-install the program or call support.
see the attached file
failed
Do you have MC15 version M010 (or higher) installed on your PC?
RichardJ
(To:ptc-4346041)
