Oct 13, 2010 1:19 PM UTC
Create a vector from the result of a function
Hi
I have a MathCAD sheet that applies a function to a range variable.
e.g. t:= 0,0.001..1
x(t):=2 * t
How can I then convert x(t) into a vecor e.g Y:=x(t)
Scott
Oct 13, 2010 1:32 PM UTC
Something like the attached?
Mike
Mike
Oct 13, 2010 1:37 PM UTC
Instead of using a range variable you could just create a range vector, see attached image.
Mike
3-Newcomer
Oct 13, 2010 2:18 PM UTC
How about
t:=0,0.001..1
Y[t*1000 := t*2
This works only because the range t is uniform...it would still work w non-uniform ranges, but not as you might expect...try w ranges as short as, say, 5, elements, and you will see what I mean...
~R~
Oct 13, 2010 2:41 PM UTC
Y[t*1000 := t*2
Do you mean Y[t*100?
This is a horrible way to go about it though, don't you think?
Mike
3-Newcomer
Oct 13, 2010 3:02 PM UTC
Well...I based my response on the original post...
e.g. t:= 0,0.001..1
x(t):=2 * t
which looks to me as if it is 1/1000 of the interval twixt 0 and 1. But I could be mistaken...at any rate, it is the technique that I am referencing...
~R~
S00tt1-VisitorAuthor
Oct 13, 2010 3:00 PM UTC
OK.
I dont quite have the answer Im looking for. I've already calculated everything and at the end of the sheet I have values for say x(t). I now need to convert x(t) into a vector. It's a big worksheet which isnt mine so cant change it much. I just need to x(t) in a vector form to transfer it to LabVIEW. t is a non-integer range variable.
Oct 13, 2010 3:06 PM UTC
Can you post the actual data?
Do you mean t is a non-uniform range variable?
Mike
Message was edited by: MikeArmstrong
Oct 13, 2010 10:12 PM UTC
so if you can create a vector for the result of a function.
then you can use the max function to find the maximum. Will this be faster than doing a solve block
Oct 13, 2010 10:21 PM UTC
It might be faster, but it will certainly be much less accurate: onlly half the increment of the independent variable.
Oct 13, 2010 11:46 PM UTC
I work with a brute force scan for minimizing, but can't find it. An algorithm without derivatives -incomplete, just for working- can be found in http://communities.ptc.com/servlet/JiveServlet/download/135434-15924/minimize_parabolic_golden.mcd at http://communities.ptc.com/message/135438.
The method of searching extremas discretizing first and looking for the maximun is usual with matlab. This also provide absolute max or min, while the derivatives methods search for local extremas.
Regards. Alvaro.
