Creating Path in mathcad
Mathcad111
I need to create paths(creating matrix of coordinates) just check image that i have given below is there any simple method to solve this ? this graph has to be plot in x and y coordinates.
(To:Mathcad111)
@Mathcad111 wrote:
Don't worry about that matrix it's just an example,
I do worry because if it should be an example of what you are looking for it should be correct and include exactly the values you would like the Mathcad function to return.
As far as I can tell from your last post this function should only be dependent on two arguments which you call x_length and y_lengths.
So the values in the matrix would always be integers
in the first column from 0 to x_length
in the second column from 0 to y_length.
But in a picture you had posted you wrote something about a step width of 0.1 in y direction which would mean at least a third argument to the function ??
11 REPLIES 11
Please include your worksheet?
Cheers
Terry
it's just a simple coordinating plot nothing much involves in that mathcad file
(To:Mathcad111)
Here is one possible way to achieve what you are looking for:
But if you are only looking for a plot like the figure to the right (with out the intermediate points and with an even number of vertical lines) there might be easier ways to achieve.
But how to control the values, i mean in x and y coordinates values? for example if i want to change from 0.1 to 1 or some other values in both coordinates..
(To:Mathcad111)
Not sure what you mean.
First you have to state if you really need eleven value across horizontally or if start- and endpoint of each horizontal line would be enough.
And then - which value(s) would you like to change? The 0 to 10 across or the upward step of 1?
(To:Mathcad111)
Here is a suggestion - not sure if thats what you have in mind
it's getting complected but the problem is bit simple, vertical line and horizontal lines can be any number please check this picture.. if don't understand just write me.
(To:Mathcad111)
Sorry, its not clear to me what you are trying to achieve.
The matrix at the right of your picture seems to be wrong, I guess, as the values in the second column beginning from row number 22 should be 2, not 1. Right?
? You always need 10 steps horizontally, never more, never less ?
? The horizontal step width is always 1, meaning that the x-values always are just 0,1,2,...10 ?
? You always need 4 steps horizontally (so we have 5 horizontal lines), never more, never less ?
? The only variable value is the vertical distance of the horizontal lines, (the y stepwidth which is 1 in your example but could be any value from 0.1 to 10) ?
1. "You always need 10 steps horizontally, never more, never less ?" NO, it's not constant value. for example if we create a function "Path(x_length,Y_length)" Here 'x_length', means just length of x here in the picture it's 10 and 'Y_length' means that length of Y in the given matrix (i mean in the picture) it's '2' (because it's 000000000&1111111111)
so lets say if we give a value to this function ("Path(x_length,Y_length)") for example Path(10,1) than i should get check the picture
2. "? The horizontal step width is always 1, meaning that the x-values always are just 0,1,2,...10 " NO, this is also not constant, we can change.
I hope you got i want i'm trying to say.. if not.. it's i will go with One more explanation.
And thanks for response
(To:Mathcad111)
Thanks a lot for your time, "But in a picture you had posted you wrote something about a step width of 0.1 in y direction which would mean at least a third argument to the function ??" - Yes, and this problem is solved.
