Creating a template from File-new?
JBlackhole
To all,
I am wondering if there is a way of having a user-defined template available from the File/New menu ? I am created the layout of a calculatin template and would like it to be available from the drop-down menu.
Regards
JXB
(To:JBlackhole)
Store yout template in Mathcads template directory and it will be offered automatically the next time you chose file/new. In case of a multi language version you must be aware that there is a template dir for every language.
(To:JBlackhole)
Thanks. Spot On. Need IT guy help because of access issue but at least I know what to do. Much Appreciated
