Creating a vector field plot
rdelascasas
I am trying to create a vector field plot following the instruction on the Mathcad 15 help.
I used the example for the case of two matrices.
But the matrices have a suffix (I used 3 and 2 above respectively), this suffix number is not explained on the example for the Mathcad 15 help.
Can someone tell me what the suffixes mean?
thank you in advance,
Rogelio
I'm Mathcadless at the moment, so can't say precisely why you're seeing 2 and 3, however ...
F is an example of what is referred to a nested array,  that is,  each of its elements is itself an array. In this particular case,  each element is a vector.  So the expression first gets the contents of F's element (i,j) and then gets element 2 or 3 of the resulting vector.
There is no reason in principle why a nested array's elements themselves could not nested arrays,  and so on.
Stuart
RichardJ
(To:rdelascasas)
The function V returns a two element vector as a function of x any y (i.e at each coordinate x,y there is a vector, not a scalar, value). So each element of F is a two element vector, in which the first element is the x component of the vector, and the second element is the y component of the vector. As Stuart notes, that means F is a nested array. To create the vector field plot the x components and y components need to be separated into two matrices. So this:
(indices 0 and 1, not 3 and 2, as your show) splits the first and second elements of each vector at coordinate i,j into tow separate matrices.
Edit: Perhaps this will help. This is the top left corner of the matrix F:
I think that I got it.
Thank you very much.
