Curve fitting - Creep Coefficient - While loops - Mathcad 13
MB_12486492
I am looking for an implementation of a program for curve fitting. I have already achieved a good approximation using the genfit function.
Currently, I am trying to improve the fit further by using a routine with while loops that iteratively adjusts the three variables to achieve a better approximation.
However, when I start the loop, it runs indefinitely and fails to find a solution. Could anyone help me resolve this issue?
(To:MB_12486492)
Ah, I had overlooked that you wrote MC13 in the topic.
Find attached the file saved in MC13 format.
Comparing the three fitting functions it shows (especially in the log-lin plot) that neither provides a good fit for x-values below 100.
For higher values of x, minimize and minerr returned a much better fit compared to genfit.
19 REPLIES 19
(To:MB_12486492)
You have to make ajpha1 an additional argument of functions Phi3P and also Delta as otherwise always the same function Phi3P is used, not considering the change in alpha1.
BTW, are you sure that it should read "< 0.0005" in the while condition and not "> 0.005" ?!!
I don't think that you can improve genfits alpha value with your method, which is also very inefficient concerning run time. You should rely on the built-in algorithms an may consider using minimize or a solve block with minerr instead of genfit.
You may test and also plot the cumulated absolute error values
Using this test function you may also use "minimize" to get the best value. It differs a liitle bit from the value derived by genfit and according to the test function its a little bit better.
But this is only a near to optimal value considering that beta and gamma are constant.
Your fit needs you to jiggle around with all three values at the same time, though.
So why not set up the test function dependent on all three and again use minimize:
The result is clearly much better than what genfit could come up with.
While we are at it, we can also try a solve block with minimize
The fit now is even (very slightly) better!
MB_12486492
(To:Werner_E)
Thank you for the quick response and detailed explanation, Mr. Werner_E.
Although your explanation of the algorithm is clear, I would like to access your Mathcad file. However, it seems your version is newer than mine ( I am using Mathcad 13.0 ). Could you please save the file in this version for me?
(To:MB_12486492)
MB_12486492
(To:Werner_E)
Mr. Werner_E,
I recently asked you for help, and you provided several options that could solve my problems.
I cannot thank you enough for your support, as it is greatly contributing to my research.
May God bless you.
(To:MB_12486492)
You are welcome.
BTW, I found that genfit provides a fit similar to minimize or minerr using your error function, when we omit the first six data entries:
MB_12486492
(To:Werner_E)
Mr. Werner,
I have a question that is not directly related to my initial query, but I would like to understand it better.
Why is a "log-lin plot" used to analyze the results?
(To:MB_12486492)
@MB_12486492 wrote:
Mr. Werner,
Because the x-values span a wide range and I noticed that the distance between the x-values was rather small in the lower range and much larger in the range of higher values. Something typical for equally spaced log values. So I thought I would try a log-lin plot to have a better look at the lower range values.
MB_12486492
(To:Werner_E)
I agree with you that better results could likely be achieved using "minerr" and "minimize."
However, I am curious to try finding the optimal values for "alpha," "beta," and "gamma" using an iterative process with a while loop. Unfortunately, it hasn’t been working in my simulations.
Do you think this approach is feasible? Is there a way to make it work effectively?
(To:MB_12486492)
For the program on the right hand side, function Delta would have to be (re)defined with alpha, beta and gamma as its additional arguments.
To return all three values, you would have to return a vector of values.
But to achieve a good result you would have to change the the three values independently from each other. he way you try to do it they change synchronous, every iteration step would increase all three values for 0.001.
You could use three nested for loops and keep the values which create the minimum value of your error expression. This approach would take up a lot of time and will sure not give better precision than the built-in methods.
I also wonder why you use gamma=45 as start value.
And, no, I don't think a simple approach as you show is feasible in any way.
If you really don't trust the built-in algorithm, you will have to study the various non-linear multidimensional solve algorithms. Most are based on Newton with a twist or two. Then you would have to implement the algorithm of your choice yourself in Mathcad but I don't think that you will gain precision or calc time that way.
Mathcad by default uses an optimized Levenberg-Marquardt algorithm for genfit, Conjugate Gradient algorithm for minimize and Levenberg-Marquardt for minerr.
You can change the algorithm used when you right-click the keyword genfit, minimize or minerr, but usually the defaults are best choice.
Not every algorithm is available for all functions.
MB_12486492
(To:Werner_E)
Thanks for the answer, Mr. Werner,
I really trust in the built-in algorithm and I am very satisfied with the precision.
I guess it is much better than I was thinking before, using an iteration process.
I would just like to have the script (perhaps with coarser increments) to compare in my research and show that functions like genfit, minimize, and minerr have a much better approximation with a lower computational cost.
Initially, I tried to model with a for loop, but I am not writing the correct script using (MATHCAD 13).
Is it possible to get any help or any link that could have a good example ?
(To:MB_12486492)
You sure should lookup the syntax for a for-loop in Mathcad in the help!
Here is the implementation of the aforementioned brute force method.
Within a given range and step width for each of the three parameters the error function is evaluated for every value of alpha, beta and gamma and the values which yield the minimum are returned.
The method is highly inefficient and sure not recommended.
The example shows very large step widths (0.1, 30 and 0.1) to speed up calculation - only 72 calls to the error function are made..
If you use step widths 0.001, 0.5 and 0.001 instead, slightly less than 20 millions (19 420 821) calls to the error function would be made and this sure would take VERY long and the precision still would be rather unsatisfactory.
Here are the results of using a finer grid and needs 'just' 22 050 calls to the error function. It already takes a few minutes to finish and while the precision is not very high, the fit already looks much better:
MC13 sheet attached
(To:Werner_E)
Another possible approach is a Monte Carlo simulation.
Generate a certain number (parameter N) of random values ​​for alpha, beta and gamma within a given range (parameter vectors A, B and C), calculate the error function for each triple and return the parameters that give the smallest value.
The picture shows a run with 10^4 random triples. Every new run (F9) will give you slightly different results, of course.
MC13 file attached
MB_12486492
(To:Werner_E)
Thanks Mr Werner,
Could you please convert this last one for my version (Mathcad 13.0) ?
(To:MB_12486492)
Damned! Actually I thought I had done so.
Hope it works this time ...
MB_12486492
(To:Werner_E)
Dear Mr. Werner_E,
I am trying to gain a deeper understanding of the functions genfit, minimize, and Monte Carlo Simulation beyond what is covered in the Mathcad tutorial. Do you have any documentation, articles, or resources that provide a detailed theoretical explanation of these functions?
Thank you for your time and assistance.
(To:MB_12486492)
@MB_12486492 wrote:
Dear Mr. Werner_E,
Unfortunately, I can't refer to any more literature on these topics.
What I named Monte Carlo was just creating a larger number of sets of random parameters and returning the set where your error functions returned the lowest value. I also have no experience in using the built-in 'montecarlo' function of Mathcad.
LucMeekes
(To:MB_12486492)
This is information provided for the genfit() function in Mathcad 11:
Comments The functions linfit and genfit are closely related. Anything you can do with linfit you can also do, albeit less conveniently, with genfit. The difference between these two functions is analogous to the difference between solving a system of linear equations and solving a system of nonlinear equations. The former is easily done using the methods of linear algebra. The latter is far more difficult and generally must be solved by iteration. This explains why genfit needs a vector of guess values as an argument and linfit does not.
Algorithm Levenberg-Marquardt (Press et al., 1992)
Regarding minimize(), it refers to maximize():
Comments By default, Mathcad examines your objective function and the constraints, and solves using an appropriate method. If you want to try different algorithms for testing and comparison, you can choose options from the popup menu associated with Maximize (available via right mouse click), which include:
• AutoSelect—chooses an appropriate algorithm for you
• Linear option—indicates that the problem is linear (and thus applies linear programming methods to the problem) − guess values for var1, var2,... are immaterial (can all be zero)
• Nonlinear option—indicates that the problem is nonlinear (and thus applies these general methods to the problem: the conjugate gradient solver; if that fails to converge, the quasi-Newton solver)—guess values for var1, var2,... greatly affect the solution
• Quadratic option—indicates that the problem is quadratic (and thus applies quadratic programming methods to the problem)—guess values for var1, var2,... are immaterial (can all be zero)
• Advanced options—applies only to the nonlinear conjugate gradient and the quasi-Newton solvers
These options provide more control for you to try different algorithms for testing and comparison.
You may also adjust the values of the built-in variables CTOL and TOL. The constraint tolerance CTOL controls how closely a constraint must be met for a solution to be acceptable, e.g., if CTOL were 0.001, then a constraint such as x < 2 would be considered satisfied if the value of x satisfied x < 2.001. This can be defined or changed in the same way as the convergence tolerance TOL, which is discussed further in connection with the Find function. Since Maximize can be used without constraints, the value of CTOL will sometimes be irrelevant. Its default value is 10-3.
For an unconstrained maximization problem, the word Given and constraints are unnecessary.
Algorithm For the non-linear case: quasi-Newton, conjugate gradient
For the linear case: simplex method with branch/bound techniques (Press et al., 1992; Polak,
1997; Winston, 1994)
References:
Press, W.H., W.T. Flannery, S.A.Teukolsky, and B.P.Vetterling. Numerical Recipes in C. Cambridge University Press, New York, 1992.
Polak, E. Optimization – Algorithms and Consistent Approximations. New York: Springer-Verlag, 1997.
Winston, W. Operations Research: Applications and Algorithms. Belmont: Wadsworth, 1994
MB_12486492
(To:Werner_E)
It worked very well,
I was trying another approach to stop when a certain precision is reached, but I am making some mistakes.
(To:MB_12486492)
Forgot to transpose the return vector.
0.005 is not a very ambitious value. You may try 0.00036.
Lower values return an error which means that no triple was fund which yields a lower error value.
I changed the return value in this case from a simple NaN to a 3x1 vector of NaNs.
You may try to decrease the step widths then - of course at the cost of calculation time.
IMHO the Monte Carlo approach gave surprising good results within reasonable calc time - so for a brute force attack (as opposed to using a more sophisticated Newton like algorithm) I would vote for it.
