Data not plotted with reversed axes
mbond
With Mathcad 14 M020 (14.0.2.5), a major bug when plotting data:
When the vertical axis is reversed (i.e. the lower end of the range on top, the upper end on bottom), the data points are not plotted; only the lines are.
The same when the horizontal axis is reversed.
(It worked ok with old Mathcad 2001 Pro).
Thanks for any help/fix.
RichardJ
(To:mbond)
