On 10/31/2009 10:07:21 AM, carla25 wrote:
== In MathCad, if I define A:= B+1, I must define B above A in order to get the A value. Is there any way that I can define B below A but still get the result. In excel I can do this....
Yes, but you have to be careful.
Use a global define operator, ≡ (press ~ to get it. Mathcad evaluates a worksheet in two passes. In the first pass, it evaluates any global definitions), then starting at the top again evaluates 'normal' definitions taking into account any global definitions.
See attached.
Stuart
