Define discrete function
ptc-4908634
Dear MathCAD-Experts,
I've a for sure very simple question: How to define a discrete function? Please see the picture attached. I want to define the function c_W(phi_Wind) with discrete values. So for example c_W(30°) should be equal to 8.2 m/s.
Thank you very much for your help,
Muh
RichardJ
(To:ptc-4908634)
I should have said "lookup", not "vlookup".
11 REPLIES 11
Attach please the Mathcad Prime file!
See cspline and others some functions.
Please see attached
RichardJ
(To:ptc-4908634)
When you lookup the angle, what are you expecting as a return value?
8.2 m/s - I want to get vector for c_W(phi_wind) as defined in the table and in case of I'm addressing a specific angle (r_W(30°) I want to get the value that refers to this angle.
RichardJ
(To:ptc-4908634)
See the vlookup function in the help.
With vlookup I can only search things in a vektor but I want to define a solution vector of a function!?
RichardJ
(To:ptc-4908634)
Mmmh...it is one part of the solution. Thank you!
I tried to work with it, but in the following equations it does not work. When I enter c_W(phi_wind)= I want to get a vector with [9.1, 8.2, 10.1, 11.3, 10.3, 10.4, 11.5, 13.6, 12.3, 11.6, 10.6, 10.7]. Then the following things work. It is like the solution vector of a function, but I want to define the solution without formula.
Sorry, it was my mistake! It is wooooooooooooooorking. Thank you very much!
tietjee
(To:ptc-4908634)
I would recommend writing a program with statement to select the correct values for each angle. You even add in a feature if 25 degree use 30 degree values. Hope this helps
I tried this in every imaginable way, but it seems that MathCAD does not allow that...
