Is it allow to print first 10 pages in a mathcad worksheet having more than 10 pages?
Why I have the question is due to human error most of the times wrongly print unwanted pages also.
Thanks and regards
Thinesh
You can specify the pages you want to print in the print properties (in the main menu select "File" -> "Print" -> "Print Range"):
VladimirN
Thanks for quick response.
This what we following .Instead of this print range enter in print setup any other master setup available in mathcad to avoid the print range enter by user?
Thanks and regards
Thinesh
Don't know if an answer is still needed, but for whatever its worth:
If you are looking for something similar in Mathcad as in Excel to define a print area - ther is nothing compareable.
If you mean by "users are printing unwanted pages" the pages which are generated because some regions go beyond the right margin over to the "next" page, you can avoid printing them by checking "Print single page width" in File/Page Setup. You may want this to be set on the template file normal.mct so every new worksheet created has this setting per default.
