Defining matrice members as variables
ptc-5125091
So i kinda have the same problem in these 2 problems.
First one is:
In whiich i have to find the values of A and B members.
And the second one is:
In which 3 of the members have the value of 0, 3 of 1 , 2 of 2 and 1 of 3.
In both of those i am having trouble in defining the matrices and using those matrices to find solutions.
Any help is welcome.
5 REPLIES 5
(To:ptc-5125091)
Mathcad won't do it that easy out of the box, especially the second one, but it can help alot in solving the task. For example the second one:
As with the ideas for the second problem from Werner, Yon can use the symbolic engine to provide some help with understanding the matrix multiplication:
But in this case a solve block will produce an answer:
Note that I have included conditions for all the zero elements in the arrays.
If these are omitted the result could include non-zero elements here.
There are also 4 highlighted equations (currently disabled).
Your initial information has 10 unknowns, but the matrix equality only provides a maximum of 16 equations - so this is only 1 of many solutions.
Adding / changing these 4 equations or the initial guess values will give alternate answers to the problem.
Regards
Andy
You changed the definition of matrix B.
With the original definition we get a pretty integer result:
BTW, with your changed information you have 20 unknowns and only 16 equations.
The original task has 16 unknown and 16 equations.
My mistake - problem is, as always, not reading the information correctly.
(To:Werner_E)
Here''s a solution for #1 without manual intervention and without the need to address the individual matrix elements.
