DelphiXE2 and Mathcad Automation
Daniel2
Hi all,
this is my first post to this forum so please be patient with me 🙂
I have troubles to use the Mathcad Automation Type Library (MathCad v15) in Delphi XE2.
When i import the library to my project, its not possible to compile anymore.
Following error occures in the source of my exe
Application.Initialize -> [DCC Error] ump.dpr(14): E2018 Record, object or class type required
Application.MainFormOnTaskbar := True; -> [DCC Error] ump.dpr(14): E2018 Record, object or class type required
Application.CreateForm(TForm1, Form1); -> [DCC Error] ump.dpr(14): E2018 Record, object or class type required
Application.Run; -> [DCC Error] ump.dpr(14): E2018 Record, object or class type required
This is how the TLB was imported::
View -> Registered Type Libraries -> Choosing Mathcad Automation API -> Import -> Adding unit to project
What am i doing wrong?
Daniel2
(To:Daniel2)
So, i dismissed the plan to use type libraries, im using Olecontainers now. Seems to work fine.
But i have problems to use a vector or matrix as input parameter for the MCadObject.SetComplex instruction.
My source code looks like this:
procedure TForm1.CalculateDocClick(Sender: TObject);
var
arrGeom:olevariant;
begin
arrGeom:=VarArrayCreate([0,1],varVariant)
arrGeom[0]:=1;
arrGeom[1]:=2;
MCadObject.SetComplex('in0',arrGeom,EmptyParam);
MCadObject.Recalculate;
end;
How do i setup the matcad-file to work?
I tried to use this
in0 =0
and this
(a b)^T := in0
Both failed 😞
Can someone help?
