Differntial-algebraic equation DAE - chemical reactor
fgörlich
I have a question to solve a DAE-system of a chemical reactor. In the picture you can see a minimal example. Its a simple reaction A to B with a first order kinetic multiplicated with an arhenius equation and an empirical pressure factor. To solve the DGL system, I have to predict the pressure p, wich depends on the mol fractions and temperatur. So this is my algebraic equation. This equation is combined with a DGL of the energy balance and two mass balnce. How can I solve such a system? With the example of mathcad, i can't solve this. Is there a simple way or standard method? I want to solve the system with RADAU so i have to built the vector function D. How i have to implement the pressure equation?
Thanks for your help
8 REPLIES 8
Sorry, I have not Prime 4
But someone I have here
Chemical Kinetics with Mathcad and Maple
-MFra-
(To:fgörlich)
F.M. написал(а):
It is not a temperature - it is one coefficient?
It is evident that the unit of measurement is incorrect. He must use the most appropriate one.
It is a simplification of an antoine-equation. Its a fit parameter.
The equation of arhenus was wrong. I correct it. But i only need the method to solve a DAE. The values of the parameters are only for the prediction. they are not messured or physically correct.
mvenich
(To:fgörlich)
Before anyone spends time on this, you need to resolve all the typographical errors in the Mathcad worksheet.
For example, in the parameters you have m_FA, but in the equations you have m_AF, etc
DJF
(To:-MFra-)
As an interesting aside, negative absolute temperatures are actually possible.  Although they are hotter than infinite temperature ...
A temperature below absolute zero | Max Planck Society
Negative temperature - Wikipedia
-MFra-
(To:DJF)
... it sounds to me almost as if I say something goes at a speed v> c. I agree that numerically everything is possible...
