I've been using Mathcad 15 extensively for about a year now and a few days ago all of a sudden I couldn't put symbols on my 2d graphs. The existing graphs weren't affected but if I changed an existing graph with symbols on it I couldn't get the symbols back.
Has anybody else seen this and if so what did you do about it? I haven't checked out 3D graphs
Thanks for letting me know. Whom can I contact to add my voice to the plaintive hoards crying out for a rapid response to a simple yet significant functional deficiency?
Regarding the image, I thought I used the camera icon but I will try it again. I am have trouble with this reply system though. I have gotten an error message when I clicked the "add reply" button. It could be our internet connection.
It sounds to me like your Mathcad installation is corrupted. Try repairing it.
I tried that. When I found the problem I figured that it was a good time to upgrade from M005 to M010 When I did that the problem was still there. However, I have done a little more research on this and have found that if you switch the x-axis limits the symbols disappear. I would like to show you this but I can't load images using this discussion. When I try to load an image (approximately 6K) I get "ID is null or not an object"
No need. It's a known bug. It was first reported back in March 2008. We are still waiting. They also disappear if you reverse the y-axis.
How are you inserting it? When you are in the editor click on the camera icon (about in the middle of the toolbar). Then you can choose an image to insert:
