Display 3D Plots
WanTschen
Display 3D Plots
my Problem is to display 3D Plots. Disabling the boarders will show my plot until i scroll in the document.
I found another solution to reduce color depth to 16 Bit, but Catia dislike this changes not even Wn7 Aero runs on 16 Bit.
I noticed this problem on various machines running MC14 and MC15(trail). Prime1.0 does not support 3D plots
Did I mixed up a bug with a feature? What's the point anyway?
Is there a workaround for the 3D Problem?
Thx
Try the following steps:
1. Update drivers for video cards (up to the latest available version).
2. Turn off the "Aero" when working with Mathcad.
P.S. Oh I see, you have the latest driver 275.33 WHQL (2011.06.01).
8 REPLIES 8
Hello!
In what operating system you are running?
Win7 SP1x86, W2K8 SP2 x86, W2K8R2 SP1x64
But I'd prefer my Win7 machiene. (AMD X4, 4GB RAM, Nvidia GT240 (275.33WHQL) )
Tried to run it on my AAO110 Netbook with XP. Seems to be working, but with bad performance
Udo
(To:WanTschen)
Hi anyone!
Attached is a simple mcd file with an attempt to make a 3D plot. It does not show the 3D graph on my AMD 64-bit Windows 7 machines.
I tried to uncheck borders and modify compatibility. No luck.
Thanks for suggestions
Udo
VladimirN
(To:Udo)
Udo, hello!
In what version Mathcad you work?
...I tried to uncheck borders and modify compatibility. No luck...
Try to contact technical support PTC, creating a new "Case" here: https://www.ptc.com/appserver/cs/case/case_logger.jsp
P.S. Plots created in the document are as follows:
I've had similar problems displaying 3D plots, the thing that fixed it for me was reducing the Colours setting from "True Color" to "High Color".
I have set everything else back to the windows 7 default state & no compatibility moes now & the plots still seem to work fine.
Regards
Andy
Thanks, Andy!
Yes, the change in color setting fixed the problem for me, at least on the 64-bit W7 computer I am using presently.
Udo
Also, try to enable "Adjust for the best performance" in "Performance Options" (see attachment).
