Displaying Results when they are very, very small
jcoolman
Maybe someone has asked this before. What about when tha result of a calculation is very small? I mean, if you work in molecular chemistry, some quantities are very small, I mean the power of ten are negative and big for these quantities. Computing an energy, MathCad 14 wrote U=0.J , but if I multiply the left side by 100000, the answer is 100000.U=8.7 e-15 J, but if the factor is 10000 (or lower), MathCad says 10000.U= 0.J again.
How can I prevent to happend this?
Thanks, I know MathCad is a great software.
6 REPLIES 6
You can increase the number of decimal places or change the formatting. Please post an example problem if this is not clear.
Mike
Like below.
Mike
You can also use a more appropriate unit, or make your own unit
As Wayne said.
Mike
One number with units must have the value from 0.1 to 1000.
1250 kg is not correct but 1.125 tonne is correct
0.09 g is not correct but 90 mg is correct
Etc
Are you saying the above is not correct Valery?
It seems to be yielding the correct answer.
Mike
