Documenting Mathcad Files
MikeArmstrong
As my list of stored Mathcad files grows by the day I thought I would create a thread for collabs to suggest the method used for filing their worksheets. I have that many sheets saved I am finding it increasing difficult to locate the functions/worksheets that I am lookinf for.
I have modified the 'Normal' template so the Vector, String, Nested Array and Cubic Splines routines appear when Mathcad is opened and they are deleted if not used when I save as, but their must be a better way of documenting all saved function, sheets etc.
Excel has been chosen software to handle my filing but it's time consuming and a little tedious.
Mike
13 REPLIES 13
Mike
>>>>______________________________
Is it possible that there is nothing to understand to what you are trying to say ?
What is Excel doing in there, in a filing system, in filing Mathcad ws ?
The matter is to organise your sheet names and Windows does the rest for you.
_Spline Bézier
_Spline Catmull Clark
_Spline Esplina
_Spline Polyline
_Spline Lagrange
_Spline Complex
_Spline Cubic_0
_Spline Cubic_1
_Spline B
_Spline Interpolate Fit
............................ etc.
Sorry Mike, what is your problem or suggestion ?
Jean
_Spline Bézier
_Spline Esplina
_Spline Polyline
_Spline Lagrange
_Spline Complex
_Spline Cubic_0
_Spline Cubic_1
_Spline B
Jean
Jean,
Your right you can organize as above but you can't really see what's in each worksheet, just have to rely on memory. I have created an Excel worksheet which gives a description of each function and a hyperlink to open that sheet.
Just enquiring how other collabs choose to file their worksheets.
Oh ! I see why Excel ... Excel as a TOC for Mathcad.
Make a Mathcad TOC directly [TOC = Table Of Content].
About the content of a specific work sheet, better have it
in the head [associative memory].
You will surely manage your own stuff.
Jean
I use a lot of folders to store sheets by category. I also tend to use long, descriptive names for the worksheets that include as many keywords as possible (i.e. words I think I might search for). For individual functions, I keep a few separate sheets and put any functions I might reuse frequently in those. They can be put in areas to group them together. Searching one or two worksheets for a desired function is much easier than searching dozens of worksheets!
Richard,
I'm just trying to get a few ideas to help with the organizing of worksheets. Some good ideas cheers.
Mike
While reading Richard filing system, I was sure reading mine !
Like a 1/1 filing system. I care less for keyword in the file name
because Windows finds in the work sheet itself, takes longer.
How often do I have to search ? Less than ½ dozen/year.
They are not all grouped by type of applications, because
some deserve their own work sheet. I have very few Given/Find
but a master collection "Given/Find" [> 80 pages] because
Given/Find is Given/Find.
Jean
Jean,
Everyone will have a different method of filing and I suppose it's what works for each individual.
Cheers for the explanation.
Mike
MIke Armstrong wrote:
Jean,
Mike
Sure Mike,
An old suggestion in Mathcad collab ,
the TOC from Xavier was well adopted.
Jean
Jean,
Mike
Sure Mike,
Jean
Cheers Jean,
Found the TOC worksheet from the old collab. Works a treat.
Mike
Before I Save As..., I think very carefully about the filename of the worksheet. I put the most important concept of the work sheet at the first part of the filename so that files listed alphanumerically sort the files accordingly.
Then, at the top of the worksheet is the extended name of the worksheet (I try to keep it to one line). The very next line is a one sentence description of the worksheet. The filename is usually a contraction of the extended name of the worksheet. For example, in a worksheet that calculates Johnson noise in a resistor, the first two line of the worksheet are:
Noise- Johnson thermal noise of a resistor
Calculate the noise power, voltage, current and charge in a resistor.
The filename I chose for this worksheet is “NoiseJohnson-vs-R.mcd”. I use automatic filename in the Header so that printouts show the filename of the worksheet. For revisions, I append 2 digit numbers (e.g., 01, 02, 03, …, 10, 11, …) so that revisions also sort alphanumerically. I’ve never had more than 100 revisions in a worksheet.
This works very well for me. Occasionally, I use Windows Search text inside file to find calculation that I’ve already done.
Cheers for the input. Thought this post was dead.
Cheers
Mike
Let me to revive this point.
In mathcad 14 you have the File/Properties dialog to insert the title, author, description, keywords, etc inside the file, like all the microsoft office files. For the file name I prefer the old 8.3 DOS rule.
In the attached, this is the metadata stored as user data
<userData>
<title>True long title (not the filename)</title>
<description>Logn description.</description>
<author>lastname, name</author>
<company>Something</company>
<keywords>keyword1, keyword2</keywords>
<revisedBy/>
</userData>
I think that you can edit your normal.mct to include some permanent topics, like author, etc, or (with notepad) to insert your own fields.
Regards. Alvaro.
Cheers Alvaro,
Very helpful.
Mike
