Does not open the program (no abre el programa)
LG_10128854
2-Explorer
Good morning, I would like to know if anyone knows why this event happens, it turned out that I was working in mathcad 6.0 and my computer turned off, once I started it again I tried to open mathcad to continue with my programming and the program never opened again, it only opens that green window and then closes.
Translated with DeepL Translator
Translated by Hedy Jin, Nov 26th, 2021
buenos dias, quisiera saber si alguien conoce por que sucede este evento, resultó que estaba trabajando en mathcad 6.0 y mi ordenador se apago, una vez lo inicie de nuevo intente abrir mathcad para continuar con mi programación y el programa nunca volvió abrir, solo abre esa ventana verde y luego se cierra
LucMeekes
(To:LG_10128854)
Some Prime administration got corrupt. You can most probably fix that by deleting (or, if you're unsure, renaming) the file:
C:\ProgramData\PTC\Mathcad Prime\MathcadPrime.exe.Config
Prime will recreate it if it doesn't find it.
Alguna administración Prime se corrompió. Lo más probable es que puedas solucionarlo borrando (o, si no estás seguro, renombrando) el archivo:
Prime lo recreará si no lo encuentra.
Also read this tip - "Mathcad Prime does not launch after the initial splash on Windows OS": https://community.ptc.com/t5/PTC-Mathcad-Installation/Mathcad-Prime-does-not-launch-after-the-initial-splash-on/m-p/729884
