The eBook is suppose to have a search function. The search function uses the idex that can be defined in the properties box. I have followed the instructions in the eBook help menu. This is the first time I have used the functionality. The eBook was large and needed to be searchable. The search is produced, but each of the first letters are dropped. Has anyone had the same problem. Attached is the files for the eBook. Ignor the broken links to the excel sheet. M241 is the handbook name. Some the supporting files are too big to post, that should not make a different in the search function.
