Energy Transfer Across a Heat Exchanger
TudorMarin
Description:
Heat is being transferred from a hot to a cold stream across a heat exchanger according to the schematic below.  The mass flowrates, input temperatures and specific heat capacities of both streams are known, as well as the heat transfer coefficient and heat transfer area.
This worksheet will calculate the temperature of both output streams.
0 REPLIES 0
