Did you look at Valerys post? It seems that Mathcad is not good at solving diophantic equations and so all I can think of is to try it with brute force like Valery had shown. Look at the attached. It seems that there are quite some solutions for X=100. Calculation time quickly grows if you increase the endvalues for X and Y (the parameters of the function Sol). As you can see in the screenshotmy machine is rather slow 😉 So good luck and patience.
WE
It is one solution in/for Mathcad - in/for an engeneering office
Or you would like to have one integer solution!?
One set of integer solution seems to be 7722793 / 197 / 1 for X / Y / Z.
But Mathcad's Find seems not to be able to find it using constraints like X=trunc(X), etc.
Strange effect with symbolic evaluation without guess values. Why does MC solve for Y?
Many thanks for your help, Werner and Valery. And I have a related question :
One more simple integer task for some meditation:
One more old problem:
A smith had 8 pieces of copper, each weighing 1 pound and 8 spools. This smith made from this copper 6 kettles whith weighing 1 pound, 21 lots and 1 spool. How many lots is in one pound and how many spools is in one lot? Do you know old russian weight units - pound, lot and spool?
I've seen this problem with the answer in one old book. I could search in internet old Russian pound, lot and spool. But I found the answer by using Mathcad! Can you do it?
I think there is a lot of same task with old english/US units of mass, weight and money.
And I need help with a brief explanation for the following :
Hello again, and I have a related question :
and with my solution ( attachment ) is still a cheating-guess way. And I really need help with another way.
WE
Do you know than a+b sometime is not equel b+a - in Numeric and symbolic Math ![]()
See please http://communities.ptc.com/groups/mathcad-paradoxes
