Equation not solving in Mathcad Prime
JH_9781973
8-Gravel
  1. T(R) -> Temperature is a function of resistance.  Therefore, if I want to find out a Temperature at a specific Resistance you can plug in a value of 10 kohms and get a corresponding value of Temperature -> degrees C.  -> This is Given.
  2. 3 Constants are provided and fixed.  They are givens.
Goal -> Rewrite T(R) Equations so that Resistance is a function of Temperature -> i.e. R(T) := ???????
I would like the equation in a format where I plug in a temperature and get a corresponding resistance.
Again I am looking to rewrite T(R) as R(T):=
Can somebody help
LucMeekes
(To:JH_9781973)
Note that, due to the third power, you get three possible solutions of R for every value of T.
So here is the general solution:
With x, y and z defined numerically, you can have:
Only the first of the three solutions gives a real answer (the other two are complex).
Assuming you don't want the complex answers, you can set:
which yields:
and of course, with:
you get:
7 REPLIES 7
(To:JH_9781973)
You may use a solve block or the "root" function.
The names T_ and R_ were chosen for the function arguments (and later for the abscissa variables) to avoid conflicts with the name of the two functions. Feel free to change them as you think is appropriate.
P6 sheet attached
StuartBruff
23-Emerald V
(To:Werner_E)
Hi Werner,
Does the OP's cube enclose the other ln(R) expression, as well?
(I think the question also asked for a rewrite.  I'm guessing that didn't mean "solve by any means that works"?)
Stuart
@StuartBruff wrote:
Hi Werner,
Forget the above. You are correct.  It's my eyes that are the problem.  Definitely time for new glasses.  And there goes my new laptop fund.  😞
Stuart
As partial penance for my earlier faux pas, here's a Prime 7 symbolic solution that seems to agree with Luc's but gives a slightly different approach that is, in principle, solvable by hand using the standard cubic solution.
Stuart
LucMeekes
(To:StuartBruff)
So it is symbolically solvable with Prime as well. Can Prime do it from the original equation as well?
(I support your argument "for example, copying the wrong expressions, and failing to update the function definition after any changes to the original expression.", but you already used such an error prone action by copying the expression to the definition of rrexp...)
It doesn't look like it, Luc.  I got the standard "no solution was found" error message.
Welcome to the wonderful world of "Do as I say, not as I do".  🙂
It's actually just an exercise in risk vs performance management.   The symbolic processor (SP) is rather tardy on my PC and it was expedient to gamble on correct copy&paste for a one-time example.   Given that the SP is so reluctant to find a direct solution, any other method requires some form of manual manipulation, thus introducing risk, anyway.   The attached worksheet goes some way towards being a better example.
Stuart
LucMeekes
(To:JH_9781973)
which yields:
you get:
