Equations
Tidus
Equations
Hellou,
i have this problem. I attached Mathcad file so there is my problem. I want wiht some kind definition make result of A6000. Please help me
thanx so much
7 REPLIES 7
TomGutman
(To:Tidus)
__________________
� � � � Tom Gutman
Tidus
(To:TomGutman)
I add what i need:))thanx
Tidus
(To:Tidus)
I repair the equation.
RichardJ
(To:Tidus)
Here's what you are asking for. Like Tom, I have some real doubts that your equation is correct though. You have "a" on it's own, "a" multiplied by deg, and "a" multiplied by PI/180. That is highly unlikely to be correct. If you want to work in degrees multiply your assigned values by deg (a.0:4.0*deg), put deg in the units placeholder of the results, but do not attempt to do conversions inside the expression.
Richard
As far as I can understand in yellow ?
jmG
TomGutman
(To:Tidus)
__________________
� � � � Tom Gutman
Tidus
(To:TomGutman)
Hi thanx guys very much. JmG your solutions is what im looking for...I know that the equation is bad (the equation write my friend) and i must change it.
Vlado
