Error 1722 when installing M020
GrantThompson
I downloaded M020 and installed it successfully on my desktop machine. However, when I attempt to install it on my laptop, I get the message:
"Error 1722. There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor."
Can anyone help with this, please?
Grant
Which OS?
Richard
Hi, Richard,
Thanks for responding.
I am using Windows XP Professional Version 5.1.
Grant
From the Knowledge base:
# Error �1722. There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected� occurs when installing Mathcad.
Cause: This error generally occurs while trying to upgrade the Mathcad 14.0 from one datecode to another. Moreover is a generic Windows Installer error and is encountered for wide range of windows based products.
Solution: From Add/Remove programs, Un-install Mathcad 14, Mathcad 14 Help and Mathcad 14 Resource center. Latest datecode Mathcad 14.0 can be found here
http://www.ptc.com/support/mathcad_downloads.htm
Note:
Windows Vista users may uninstall using Programs and Features located in Control Panel.
Richard
Hi, Richard,
You are a very helpful person!
Thanks very much for the tip. I'll give it a try.
Cheers,
Grant
It worked!
Thanks again,
Grant
