I checked other posts about this issue, and I couldn't find one similar to what I am doing here
I am wondering if that is because of the sin function or what
mathcad 9.0.0 file is also attached
The question was also answered here
You have to manually label the two deltas as "Variable" or "-" = "Automatic"
would you happen to know why only delta was defined as 'function'? but not the other ones (i and Mu)?
I am wondering if I copied and pasted it from somewhere else or if it's because it is a Greek letter
It is due to the intricacies of the enigmatic 'autolabelling' feature of Prime.
It's a nice feature, and often it helps. Too often it strikes wrong.
What helps is if you make all label types look differently, e.g.:
Then you immeditely see.
Primes auto-labelling feature fails quite often.
It often fails when used in combination with symbolic evaluation and also when you start editing an expression and using copy & paste.
So I guess it had nothing to do with the Greek letter but was because of editing and using copy and paste.
Lucs suggestion sure will help spotting that kind of error.
