I am getting an error message as copied below.
I have also attached the mathcad work sheet.
Will someone be able to take a look?
It's exactly what it says: the solution is too big to display. You can break it down and display it in pieces though.
Do you mean to say, I can solve it in two pieces or three pieces.
What is the limit that mathcad can handle. I mean how many pieces should i break that into?
I am sorry. I didn't open the attachment. I follow what you said.
Thanks for helping me out.
Mr. Jackson,
I have applied the same logic to the attached worksheet and doesn't seem to work.
Wonder why not
Because you have two Find statements. The first one terminates solve block, so the second one is an orphan. Delete the first Find statement (the one without the assignment to "Solutions").
Thank you so much.
You are a scholar and gentleman
Mathcad 14/15 do not display excessively large symbolic solutions...as a conseqence of symbolic engine change
You can view the solutions...You will need to call them using vector subscripts
Thx
