Evulation problem
aalali
Evulation problem
Hey guys. I want to solve a question in mathcad, but it gives me an udunderstandable answer. How can i evaluate the answer so it's only numbers. Thanks in advance see attached files.
7 REPLIES 7
Fred_Kohlhepp
23-Emerald I
(To:aalali)
don't post a picture.
Post your Mathcad worksheet
How can i attach a file? It seem not possible.
Fred_Kohlhepp
23-Emerald I
(To:aalali)
In the upper right corner of a dialog box (when you're responding to or writing a question, the link "use advanced editor" appears. Click that, and "attach" appears on the lower right corner.
Noone can figure out why it's so convoluted
RichardJ
(To:aalali)
You need to solve numerically, not symbolically. Look up solve blocks in the help. If you still can't get the answer you want, please post a worksheet.
aalali
(To:aalali)
I have attached the file.
Given that it is an assignment (Homework - I don't want to just say - here is the answer) as that will not be helpful for you.
However, I would suggest that:
Step 1.
change the definition for I from I:= to I(x):=
This will make it a function with parameter x that you can use anywhere.
Step 2:
as Richard suggests, delete the symbolic solve and look in the help files for the numeric equivalent, in this case 'find'
the solution should be easier - but if you get stuck at some point - post the new sheet & I'm sure that you will get further pointers
Andy
Fred_Kohlhepp
23-Emerald I
(To:aalali)
Congratulations! You solved it.
Your attached sheet had a solution, just needed to understand how to read it.
