I am currently using the free trial version (EXPRESS) of Mathcad Prime. After converting a file created with the old Mathcad using the "Input/Output" XMCD converter menu, I opened the converted file and tried to copy and paste a table from Excel into the original table, but it is not reflected. During the conversion, a message "To maintain the numerical results of the input table, the table has been converted into a matrix" was displayed. Is this the cause? Could you please tell me the reason and the solution?
Hi
I also recommend the READEXCEL wizard on the ribbon that only takes a few clicks to import a matrix rather than a table from EXCEL.
Cheers
Terry
Well, apparently in the conversion, the link between the Mathcad sheet and the Excell sheet was detached. The corresponding data was copied into a Mathcad matrix.
The wonderfull new functionality of Prime is that it, contrary to 'real' Mathcad, does NOT provide a means to copy a range of cells from Excel over to the Prime sheet. Going from Mathcad to Prime there are a few improvements (Units in arrays, Solving Differential equations symbolically, and Automatic labelling of units, to name all of them) but there is a lot of functionality lost, some of which gets repaired over time, but with the speed of development of Prime. A snail runs faster.
Ah, I stand corrected.
As @terryhendicott indicates, it is possible to copy a range of cells over from Excel to Prime, but you can (only?) create a Prime table from the data, meaning you get one or more table columns where each column effectively defines a vector. As such you cannot copy a (2D) matrix over.
Hi
Cheers
Terry
Thank you for your kind advice! After trying the READEXCEL wizard, the problem was resolved.
Yes, copy&paste is really messed up in Prime.
And unfortunately, there is no equivalent to the tables in the real Mathcad (tables in Prime are something completely different). These Mathcad tables were ideal for permanently storing large amounts of data in the worksheet without having to import them from external files or integrate them via a cumbersome and slow Excel component (which also tends to fail now and then).
You could use a normal matrix as a workaround... "could", if it were possible to copy a large Prime matrix. But you can't, as unbelievable as that may sound. You can only ever copy the visible part of a matrix, and enlarging the display of a matrix comprising several thousand rows across dozens of dozens of pages so that everything is visible is out of the question.
This incompetent PTC apprentice who committed these many copy-and-paste crimes truly deserves to be tarred and feathered...
Can you please upload your Prime worksheet, the old Mathcad worksheet and Excel workbook.
I have tried to recreate the error but have not been able to do so,
Select the Excel adjacent cells, copy. Select a vacant space in the Prime worksheet and paste. You get an Input Table with no headers defined. That is the column vector variables of the Input Table have no name.
Cheers
Terry
