HI friends,
I tried to import an XLS Sheet, which was generated by MMA (with 30 digits after the comma) but get problems. The DATA is always 0.
Can anyone here confirm this with MC 15 M045?
Walter,
Could you attach the xlsx file, please?
Stuart
I get the same thing, Walter, in a slightly earlier version of Mathcad. However, when I made a copy of your file (using Save As), then the Excel Wizard/Component worked (see Data2ViaWizard).
What's amusing is that the Component shows the values in the table, but still returns 0.
I can't change the decimal symbol, though ...
Stuart
You must switch to TXT Type, then the Comma can be changed. (That keeps even when you change back to Excel) Strange!
Did you check the settings on tab "Data Range"?
Any reason why you don't use READEXCEL to get the data in?
EDIT: Ooops - your READEXCEL comment came at the same time as my answer.
Werner, yes if I do know,
But I can not select teh DataRAnge, and I want to use default as mentioned in the line.
An alternative is to resave the .xlsx file as a .xls file (from Excel). M15 then reads it via file input.
Alan
OK, that might be definitiv a bug in MC. I will use the READEXCEL Command, so I need not to make the copying.
Walter
Just saving it as (another) xlsx file worked ...
Stuart
WALTER SCHRABMAIR wrote:
HI friends,
I had a quick look at the xml data for the worksheet and compared it with the data from my (saved as) copy. They were identical and only used 15/16/17 digits after the decimal symbol.
Stuart
<worksheet xmlns="http://schemas.openxmlformats.org/spreadsheetml/2006/main"><dimension ref="A1"/><sheetViews><sheetView workbookViewId="0" tabSelected="true"/></sheetViews><sheetFormatPr defaultRowHeight="15.0"/><sheetData><row r="1"><c r="A1" t="n"><v>0.0</v></c><c r="B1" t="n"><v>0.057558404187623195</v></c></row><row r="2"><c r="A2" t="n"><v>25.0</v></c><c r="B2" t="n"><v>0.45722770760712766</v></c></row><row r="3"><c r="A3" t="n"><v>50.0</v></c><c r="B3" t="n"><v>0.7191794829918897</v></c></row><row r="4"><c r="A4" t="n"><v>75.0</v></c><c r="B4" t="n"><v>0.8758069400500752</v></c></row><row r="5"><c r="A5" t="n"><v>100.0</v></c><c r="B5" t="n"><v>0.9629897594833632</v></c></row><row r="6"><c r="A6" t="n"><v>125.0</v></c><c r="B6" t="n"><v>1.0092654027889587</v></c></row><row r="7"><c r="A7" t="n"><v>150.0</v></c><c r="B7" t="n"><v>1.033148300481165</v></c></row><row r="8"><c r="A8" t="n"><v>175.0</v></c><c r="B8" t="n"><v>1.0452862671233485</v></c></row><row r="9"><c r="A9" t="n"><v>200.0</v></c><c r="B9" t="n"><v>1.0514055831754439</v></c></row><row r="10"><c r="A10" t="n"><v>225.0</v></c><c r="B10" t="n"><v>1.054477894130151</v></c></row><row r="11"><c r="A11" t="n"><v>250.0</v></c><c r="B11" t="n"><v>1.0560171785670789</v></c></row></sheetData><pageMargins bottom="0.75" footer="0.3" header="0.3" left="0.7" right="0.7" top="0.75"/></worksheet>
Stuat, yes I tried to put it out from MMA with 30 digits, but I think that is not working. Within MMA I have 30digitx predicsion but in the Excel file there are just 15 digits.
Guess Excel can't support higher precision as it uses (like Mathcad in numeric mode) standard IEEE format to store its data.
Yes, it does use (mostly) IEEE numerical fp. https://support.microsoft.com/en-gb/kb/78113
I was wondering,though, if the problem might have been caused by MMA outputting more digits and the Mathcad component choking on that.
Stuart
I can confirm that the import works with a file that was re-saved from within Excel.
What I noticed is, that the data in the original document is stored as
but after saving (with Excel 2007, though) I see
<c r="B1"><v>5.7558404187623195E-2</v></c>
Not sure if this means anything.
I used Excel 2010 and the numbers didnt' change - might be one of those differences between versions showing up.
Stuart
I found the problem: MC 15 M045 is not compatible with Office 2013!!
I can read in the Excel Sheet made by MMA with the ReadExcel Fn. That is fine. BUT When I write out some data with the componente f.e a Matrix with 25 lines and then I do it once more f.e. a Matrix with 5 lines then MC writes in the File the first 5 lines and do not delete from the run before the other contents of the Matrix with 25 lines.
MOreover WriteExcel does not work at all. If I use the XLS Format instead of the XLSX Format, and want to open the file with Excel 2013 I get the error that the XLS is protected. So I can not resave it as XLSX or XLS.
Can anyone here confirm this, when he/She has Excel 2013 ?
Thanks a lot
Walter
