Hello ,
Is it possible to get all the values back to Excel as a product.of L*B as an area. I tried with one row but it is too much time consuming. I believe there is some other way to do may be by programming but I am not sure how to do that can please someone help.
Somehow I was unable to add excel sheet so attaching screenshot
Don
See attached.
First check the contents of Book1.xlsx.
Then open the mcdx file with Prime.
Then re-check the contents of Book1.xlsx.
Thank you for the information
Can we call out a specific combo box in a worksheet and then a specific row or a column in another combo box?
I tried calling out a excel in a worksheet using combo box but not sure if we can call out a specific row from specific excel sheet to get the calculations done in Mathcad prime 7
Read section 2 of the "what's new" in Prime 7 here: https://community.ptc.com/t5/PTC-Mathcad/Mathcad-Prime-7-0-reference-documents/td-p/719101
Then decide if this is what you need. You are more an expert on this than myself, because I'm limited to Prime Express, which implies that lots of the new features of Prime are not usable.
Regarding the Combo-box, you should also be aware of this: https://community.ptc.com/t5/PTC-Mathcad/Mathcad-Prime-7-0-Combo-Box-doesn-t-support-unit-with-exponents/m-p/718297#M194871
